One thing that I never learned was the right way to connect the 24v system of central air...any cheats available? Any good tips you want to share? Thanks!
Not sure what your asking but standard HVAC LV wiring colors are simple
Red, transformer power to the thermostat, if it is a split system with a separate heat system such as a boiler that don't have a common transformer, you will have two reds (power supply) to the thermostat, Rh and Rc, h for heat, and c for cooling
White is for heat
Green is for fan and is used in cooling or manual fan on.
yellow or blue is for condenser in cooling.
In a lot of newer equipment that has been dropped and replaced with their own markings and functions. :thumbsdown:
T If you don't have a good understanding as to how they work I would leave it to the experienced.
