megloff11x
I have a ~100yr old machine that still works but is largely unused. The building was pretty much built around it and it contains almost as much steel as a battleship. I was informed by one of my former colleagues before he passed away that he would come back as a poltergeist and haunt us if we ever got rid of it because the new machines that do the same thing are ****, etc. And he was largely correct on the 2nd point. We fired it up when the calibration service came in and it was the most accurate and consistent machine that did what it does. Go figure.
It has huge exposed gears and belts that can't effectively be covered and all sorts of other horrors for the unwary. Just don't wear loose clothing or get too close...
What I would like to do is just "lock it out." Its motor, connected to an original 1876 Reeves Variable Speed Drive, plugs in to an outlet.
I seem to recall that you can buy something to clamshell over the plug and lock out tag out the clamshell.
1. Do I recall correctly?
2. If so where can I buy one?
3. Will this satisfy safety folk/regs otherwise in great angst over giant old school exposed tooth gears and belts?
If it has to be dismantled I'll get a medium to re-direct my late colleague's spirit to torment OSHA, et. al. To me it's a piece of working history.
Let me know.
Matt
Let me know.
Matt
