Lift Station
I am powering a lift station controller that has two 80amp breakers ( one for each pump) and a 10 amp breaker (for the controller) inside the controller enclosure. The electrical panel that will feed the controller is inside the building and is about 150 feet away. Will I be required to provide a disconnect switch before the the controller (right beside it)?
Are the breakers able to be operated without being exposed to live parts?
Is the control panel a listed unit?
I don't have a definite answer yet but these things could make some difference.
I am not finding anything that says you can as well as anything that says you can't use the mentioned breakers as the disconnecting means. I have seen this type of install many times. Never gave it much thought as to whether is code compliant or not.
Smart $
Esteemed Member
Ohio
The disconnecting means for the control panel is not required to be within any specified distance, in general. I can think of one condition that may change that, such as being powered by a feeder tap, which requires the tap to terminate to only one ocpd and if inside within a specified distance from the tap location.
A tap to each breaker would be acceptable, you just can not feed more than one overcurrent device per tap.
Smart $
Esteemed Member
Ohio
Typically such taps would be inside the control panel and meet distance requirements. However, if the control panel is also fed by a feeder tap, a single disconnecting means would be required ahead of the control panel and distance requirements may kick in.
