data
can i put 8 cat. 6, cables in a 3/4 pipe. i think it will fit comfortly is it ok ?
As far as the NEC is concerned as many as you can stuff in the pipe.
But I bet typical data standards would hold you back to four cat 6s and just two 90s before a pull point.
thank you iwire. i might as well go 1". should be good. is'nt there a table for that kind of wire ? even though most of it is free air ?
110624-1322 EDT
I conjecture that if the pipe is metalic (conductive or magnetic) that this will modify the impedance of the cable and might possibly degrade performance. That would even apply to a single cable.
But I have not run any experiments to verify this conjecture.
