Gas range receptacle location
powerplay
Canada
Electrical Contractor
If the wall behind the gas range is full of pipes, venting, and the stainless gas valve enclosure, how high above center can I mount the receptacle?
Some units give precise dimensions. Normally I install it at 19" of the subfloor. But be forewarned this does not always work so having a cut sheet is important. The center does not usually work well. I try to get it to the opposite side of the gas line.
