Alwayslearningelec
- NJ
- Estimator
What exactly is the difference. I always thought when I heard someone say "I need this equipment rigged" that was using a crane.
Rigging is a means to move large pieces of equipment. It can involve a crane but not necessarily. The use of slings, hoists, dollies, skates, hydraulic jacks, etc can all be used to maneuver large pieces of equipment.
Just a heads up. A digger derrick operator needs to have a crane license, which is a DOL requirement and riggers with over head loads need to be qualified per OSHA requirements.
Some nuts that hold the crowns on large presses are on hollow rods that have a built in induction heaters. You heat the rod, tighten the nuts and it cools super tight. Smaller presses, we just used torches to heat the exposed solid rods before tightening them. Impact wrenches were so big that they were lifted by a crane!crane's aren't the only way to move something....
this was to do a 300 ton pick of a steam generator.... each of the four
jacks on the beams are 100 tons each... the load is in the second photo..
third photo is the fasteners holding the pressure vessel together. for scale,
the nuts welded over the surface to attach insulation are 1/2" nuts.
Are you sure about that? This website says that they are exempt.
http://www.nccco.org/news/OSHARuleFAQs.html
