I am not buying that, many fully trained, fully qualified, fully responsible employees have been hurt or killed through no fault of their own due to problems left by others before them.
I did not say that. Secondly, safety procedures are to protect you not only from the expected and expectable,but from the 'problems' you cite.
There is no reason not to try to shut things down.
Absolutely. Leaving power on just because it takes time to de-energize things is no reason to work live, for example. I would argue that if a safely conducted energized work can save k$100's by not idling employees, or avoids a lengthy startup, shutdown procedure that has miriads of safety hazards, or things similar in nature that it should be allowed. I have done this many times and still do feel safe the same, regardless what hype generated by special interest about the arc-flash hazard.
Furthermore, power line guys have a much higher levels of training, have much higher enforcement of safety procedures and still have the highest rate of electrocution.
So I think your are speaking from your wishes and not from facts.
Statistics allow you to make statements that sound great, but when the full facts of the base is known may put things in a different light. As an example the above statement - if I think you base it on the data I am familiar with asmost often used, but you did not state it so I don't know - bases the injury rate on total worked hours. That statistics is biased as utility workers work on higher voltage and energy levels than the compared average, AND
work live hours multiple magnitudes higher than the same group average, so their exposure is far greater than anyone else within the other segments of the group. In other words it is like stating that airline pilots have the greatest fatality rate -involving an airline incident- among all those who ever board an aircraft.
