Why are homeowners so dumb? Covering up POCO's transformer in their yard.
hockeyoligist2
I copied this from a gardening forum, I can't believe someone thinks this way!
Quote "I would like some feedback on ways to hide two large electrical transformers on both front corners of my yard. They are each about 2' high, 6' long and 1.5' wide, pale OD green in color. I want to smear some camo paint on them, but that got vetoed by the front office inside the house
Right now I am having some success surrounding them with daylilies and azaleas, but had a new thought.
The electric company has the easement to the boxes, but I thought I could build a shallow box that I could sit right on the transformers, then place container plants in the box that would spread out and cover the transformers. The purpose of the box would be to hide the outline of the transformer and to hold the containers on top so they don't get blown off during a storm. Everything could come down in a couple of minutes to allow access to the box.
I know I should check out what the Electical Company will demand, but in nearly 20 years, they have never visited these.
I am in Mid-Atlantic, zone 7a, and this is a full sun site. I am thinking I could have some shallow pans to hold water resting on the top of the transformers, also hidden by the box. Since this is above ground, this will be an early spot for warm roots to thrive, getting lots of heat and sun early in the spring.
I also know that come winter, I will need to put everything away, so annuals work. Right now I am thinking of Vinca Minor and Petunias, but would be open to suggestions of a flowering vine annual and would tend to grow out and down.
Has any one seen an attempt to make one of these transformers disappear from a yard?" Unquote
While I personally fail to understand the intensity of the desire many feel towards hiding panels, transformers, etc., I have to recognize that it exists. Perhaps it speaks well of the trade that folks do not consider the need to access equipment to be very great.
In true schitzoid manner, it also seems that the same folks who will bury a transformer in plants also consider it somehow 'illegal' to paint the things.
I would suggest a low link fence, with a large gate on the access side. There are filler strips you can pull through the fencing that resemble evergreen needles, and do a very good job of making the fence 'disappear.'
Of course, the "South" has the ultimate solution: kudzu. In a year you'll never know there was a transformer there, and in two it will be crushed by the weight of the malignant vine.
We have a commercial customer that has used a large fake rock to hid a pad mount.
Here is an example.
http://fakerock.com/
I would do the same if this was in my front yard.
That's cool!!
If their power co. is like the one from around here, I could see them wandering around looking for their transformer when the time came to find it though!!
Around here there are not many times where you would find a transformer in the front yard of a dwelling.
It is illegal to attach signs or other items to utility poles yet it happens all the time. There are wood poles that are nothing but nails for 6 to 7 feet above ground in some places. Mostly from garage sale signs being attached.
A lot of times people plant shrubs, erect a fence, or put in a berm to hide them.
Boxing them in seems kind of extreme though.
POCO may want working clearances and maybe somewhat increased distance than other equipment - especially if they need to use hotstick while working in there.
If it is boxed in this could cause cooling problems also.
POCO may move the equipment if customer is willing to pay to have it moved.
Did a new house several years ago. POCO had overhead lines in front of house near street. Owner did not want to have to look at these lines in front of the house. POCO said if you install conduit underground we will pull lines through there and eliminate poles and overhead conductors. Owner had plenty of heavy equipment and installing this raceway was no problem at all.
Today they may charge something to do this but they are still willing to work with customers on requests like that.
My neighbors put a bed around the cable TeeVee pod. Then failed to keep the plants in said bed alive.
Now they've moved and rented the place and I'm thinking about turning it back into lawn.
I get the "plant stuff around it" idea. Would just be nice if people planted stuff and made sure it lived.
Then you get the ones that get mad if the equipment they planted around needs access for work and they have to destroy some of the plants to work on the blocked item. Even meters on side of house have some of this problem.
Our neighborhood has underground utilities and the transformer for my street is in a corner of my yard. A few years ago the primary cable failed and blew up (cracked my sidewalk) forcing them to replace the transformer too. I'm glad I hadn't spent any money on landscaping that corner of my property, they tore it all up. backhoes do major damage.
I kinda like looking at them all day. Then again, I like the commerical grade wall packs on my house too. :cool:
me personally, I wouldn't dig around a pad mount. They use sub contractors around here, and they do the job as quickly and cheaply as possible.
I just personally witnessed a street light contractor hired by the town leave direct burial cable just 6" from the surface...... above lawn sprinkler piping. and the town inspector was their watching.
