Twoskinsoneman
- West Virginia, USA NEC: 2020
- Facility Senior Electrician
Recently saw Wago push in connectors listed for use with stranded and solid wire. Anyone ever use stranded in them?
			I (in my previous job) used connectors that were similar to Wagos, French made, and I usually tinned (soldered) the end of the conductors before inserting them. If I didn't have time to tin them I would strip off enough insulation to have double the length of exposed wire and fold the wire back and twist it. If you didn't do either the stranded wire was easily pulled out.
The problem is when you need to add another circuit your out of luck.
Where is the time savings with that? Isn't that the reason to use push in connectors? Sounds like twist on connectors are the way to go if that is what you need to do.
You can't use them on lights.:rant:
Adding another circuit is no problem, just use another Wago.
What gets me is when you get back to trim, and the wheels fall off in a dozen different ways. You can't use them on lights. You can't use them on smokes. Your timer or dimmer comes with tails already attached? Whoops....
Not to mention when people find new and creative applications for them, and cause even more headaches in the field. Not to mention having to stock and carry around another connector in addition to wirenuts, find an unused compartment in your tool bags for those...
I hate the stupid things with a passion, and get irritated when I am forced to use them - crummy connection aside, of course. :rant:
The title of this thread sounds like someone in a remote area waiting for connecting flights or trains to someplace named WAGO.:lol:
