DOA_Kilovolt
 - Upstate NY
Installing heavy wall packs on corrugated aluminum siding?  What is your ideal installation method ?
Structure is steal beam with horizontal girts @ 4', 8' and 12' at header beam.
I usually go the long way and install 2 upright struts from the 8' high girt (sheeting rail) up to the header beam. Then 1 cross strut at the height of the top hole in the wall pack. 3/8 rod through siding at the 3 attachment points with backer nuts behind the siding so you dont wrinkle the aluminum.
