 - Mission Viejo, CA
 - Professional Electrical Engineer
Well, also consider 501.30. Proper bonding in a classified location, even Divsion 2, is critical. Personally I wouldn't require the MCC to be service rated in an industrial facility with this application (as I said the engineer is correct)Should I require that the MCC supplying these loads be service rated and bonding in the class I Div II building be per 250.32(b) and call it good?
