sump pump in unfinished basement
domnic
Electrical Contractor
can i use a single recepticle for a sump pump in an unfinished basement
or must i use a gfi?
If you're in New Jersey the single receptacle without GFCI protection is permitted. As Bob mentioned the GFCI requirement is for 15 and 20 amp, 120 volt devices. You could go to a 240 volt pump and use a non GFCI-single receptacle also.
