A anbm Senior Member Location TX Occupation Designer Jul 19, 2011 #1 Can electrical conduits from utility xfmr to building share same trench with natural gas and cold water pipes? I would say yes but not 100% sure
chris kennedy Senior Member Location Miami Fla. Occupation 60 yr old tool twisting electrician Jul 19, 2011 #2 Sure, if you dig a wide enough trench. Around here the utility providers have separation requirements. This can be accomplished by staggering both elevation and horizontal separation.
A anbm Senior Member Location TX Occupation Designer Jul 19, 2011 #3 What is minimum separation (ft) between two different system conduits? Or this depends on AHJ?
tkb Senior Member Location MA Jul 19, 2011 #4 You will need to get this info from you local power co., gas company and AHJ.
