ohmhead
- ORLANDO FLA
Well i have a question balance load on 3 phase panel .
I was asked why so here it goes if you had 48 motors each at 11 amps 208 volts single phase no other load in panel .
So i took the 48 motors and equally put 16 on each phase A B C .
Next i took the total wattage of each phase with 16 motors attached 11 amps each and total them up of 16 on each A or B or C using one phase total on one leg .
Since there all the same thats what i used for my load i picked one phase and came up with around 178 amps .
I took the largest motor of the 16 and went 125 % of added that into load and picked my wire size .
I figured around a 200 amp panel and wire size ?
What is your way ?
I was shown to balance the load on each phase .
That ab bc ca rotation wise and that each motor only sees ab bc ca if iam wrong please let me know ?
What is your way ?
