MoleculeMan
- New York
A term-a-nut pigtail with fork connector was installed in an outlet box. A gfci receptacle is to be installed in this box but if the fork connector is attached to the gfci ground lug, there is not enough clearance and the receptacle will not fit the box. If the fork connector is removed and stripped everything's fine. By modifying the pigtail, I assume UL listing is lost. True? Does the NEC care?
