Is it okay to have 2 pronged outlets ( this is an old house) all throughout a house or are you required (NEC) to have a certain number of 3 prong (grounded) in certain rooms of a house.
Outlets with 2 or 3 prongs are both dangerous.![]()
	The State of Wv adopted the 2008 NEC along with the 2009 International Property Maintenance Code (IPMC). Part of the IPMC requires "Every laundry ares shall contain at least on grouned type receptacle or a receptacle with a ground fault circuit interrupter" The other receptacles can be of the non grounded type.
Four prong receptacles are the safest.
Roger
:blink: Well, that takes care of the ground up/ground down issue!
