#10 or smaller in raceways can be solid or stranded. Solid conductors can be any size if not in a raceway. Many guys use #4 solid copper for GEC's.
I have seen solid #2 but not any larger.
I've seen #2/0 solid copper in MI cable.
Wow! I couldn't be happier that I have never had to touch that! How on earth are you even supposed to bend that?
I think you meant to say "Many WEALTHY guys use #4 solid copper for GEC's".Many guys use #4 solid copper for GEC's.
I think you meant to say "Many WEALTHY guys use #4 solid copper for GEC's".![]()
- Ditto. Tinned solid copper. Sprint wanted it for a ground wire loop around some cell equipment. Bought it from Tessco.
Are you required to use # 4 solid or is it just your choice ???I use 4 solid all the time to water pipes. Lately , of course, the water lines have not been metallic, however on remo's there is often copper. I didn't learn til recently that bare solid cost more than thhn.
My choice. I use #6 solid to the ground rods. I believe it is the way everyone around here does it. On a 400 amp service I use #2 THwn stranded.
That is correct. Why pay for something you're not required to provide. Don't misunderstand, I don't take the cheap and dirty way out when it comes to installing services. Unless I have to match something existing I generally use Sq D or CH breaker panels. But if the code allows me to use stranded # 4 THHN copper wire to bond to a water line then I'm not that nice of a guy where I'll spend the extra $$ to use solid copper. By the same token there are guys in my area that will only use copper wire and PVC for their services. Their prices will almost always be higher than mine because I'll use ALUM-SE cable. Both jobs are code compliant. Both jobs pass inspection. But, my material was less expensive.I'm sure that Goldstar is asking because no one here use sold bare copper except for pools.
