... Do you trust that the building steel will stay continuous?
I think he's questioning whether the structural framework will maintain its integrity after installation or stay intact through remodeling after having used it as an electrode. Say for example, one framing member meets the in-contact-with-earth requirement and it is on the other end of the building from where the system is bonded to structural steel.It depends, in many existing buildings or buildings under construction you can clearly see the steel is continuous.
OTH there are buildings being remodeled that you may not be able to tell and in that case I would run a wire conductor.
