I played it safe, but don't agree AC solar is a lot safer than DC
AC microinvertors panels & section 705 are so new, if they don't know they just refer back to section 690. When I installed the inspectors did not know enough & wanted me to do some of the section 690 rules, I politely showed them 705 rules & how the Mike Holt solar video's explained it. But I still think section 705 needs a lot of work. I used all the best rules of 690 / 705 & I know some were overkill, I didn't care because this is my personal house. I just think that there is some cost that can be cut safely when installing AC panels from section 705.
EX: 690 has us running pipe & 690.31 E 1 pipe min 10" below roof line for firemen.
AC microinvertors drop out within a second of main power grid loss, unlike DC. AC power relays kick back in after the power grid or main power source is on for 5 minutes unlike DC. My point is why piping, 10" rule etc, when I'm walking over all the over AC circuits in my attic, there is no difference. I'm just backfeeding.
EX: I ran pvc piping from the panel to J box, with a expansion coupling in the attic. From the J box a 6' flex whip to the panels. I pulled THWN-2 stranded wire. This is all I could find approved & affordable.
I put a pull out disconnect box on the roof, didn't have to because 705.12. D1 covers me with a breaker, but I needed a weatherproof j box to connect my flex to there approved exposed to weather cable that lays on the roof, under the panels, get my point again. THWN-2 strained and all the wire was completely watertite & not getting any sunlight, THWN-2 is overkill in my opinion.
What I do like is 705.10 directory, 690.5 C markings, 690.31 E 3 marking boxes, etc, 690.31 E4 every 10' labels & markings, 690.4 B 1-4 E indentification, and my favorite disclaimer 705.30 A just ref 690.
I got no problem indentifing two power sources & always being safe, I just think there needs to be an affordable color coded cable, to cut down cost, because the solar guys have done a good job making affordable alternative energy and the NEC needs to help also. Everybody needs to be a little greener and cost was the biggest hold up.
Just some thoughts of mine & thanks for the feedback, I 've been checking into USE-2 RHW cable.
Take Care Bill
I was waiting on one of the Solar guys to step in, but in the meantime, in my limited experience, the only one I have found is a cable with RHW/USE-2 ratings
690.31 allows the USE-2 and RHW is an acceptable conductor for most raceway installations. In addition, the cable I see, manufactured by Southwire, is sunlight resistant.
