Ron Gough
New member
 - arlington va
In a single family dwelling what is the NEC intent regarding required receptacles and spacing in an indoor basketball court? I can't see using standard room spacing in such an area.
I'd say it would depend on whether the Authority Having Jurisdiction considers the basketball court a kitchen, family room, dining room, living room, parlor, library, den, sunroom, bedroom, recreation room, or similar room. I'd suggest asking the AHJ.
Well, you wouldn't think so, but the code reference does include "recreation" rooms. And although its a basketball court today, it could be a huge living room tomorrow.
Some one could also come in later saw out the floor and put in an in ground pool.
Someone could also fill this basketball court with tables and chairs for their daughters wedding reception, now it could be a 'place of assembly'. Better not use NM cable for the receptacles that are placed every 12 feet.
Only someone on the scene can make the call. There's a lot to be said for looking at things in context.
The question is not whether a room can possibly be used as a 'habitable' room, but whether it is intended to be one by design.
Of course the install wouldn't have to take these possibilities into consideration. You don't have to assume its a place of assembly, and you don't have to make the install suitable for a swimming pool.
But the code does say receptacles have to meet the spacing requirements in rooms like kitchens, family rooms, dining rooms, living rooms, parlors, librarys, dens, sunrooms, bedrooms, recreation rooms, or similar rooms.
And I think part of that requirment may be because the CMP's realized room uses and furniture needs do change frequently.
I know we don't have to plan everything out for what might happen in the future. But you also can't just say "They won't need furniture or electric appliances in a basketball court." as an excuse to completely ignore a code rule.
I'd call it a garage with a really nice floor.
One cannot peer into a crystal ball and determine what the occupant will REALLY do, nor can we prepare for EVERY contingency.
Nor can one ignore the circumstances specific to every situation.
Up at Tahoe, I have seen massive hotel-size homes with pro-grade handball courts, movie theaters, libraries, greenhouses, work shops, recording studios, wine cellars, and heaven alone knows what else. I have also seen 'garage-mahals' that were ultimate man-caves, with every creature comfort imaginable.
"Can" someone do something? Sure they can .... but at some point we need to get real. A basketball court, of 'pro' dimensions, isn't really well suited to conversion into much else. Who wants to hang a chandelier from the net hoop?
Only someone on the scene can make the call. There's a lot to be said for looking at things in context. The question is not whether a room can possibly be used as a 'habitable' room, but whether it is intended to be one by design.
