On a tent is it required to bond all of the poles and cables together when installing temporary lighting in them?
The tempoarary tents are 20x20 and have 4 aluminum pipe legs (1 in each corner) and 4 aluminum pipe runners that run horizontally between the 4 legs at a height of 10'.
The 4 corners are tied together by a 1/2" cable that runs diagonally from corner to corner and the 2 cables cross in the middle of the tent at a height of 10'
There is an 8' center post that is in the middle of the tent. The base of the center post rests where the 2 cables cross an the top of the center post supports the peak of the tent.
The bottom of the center post has a nylon cross hatch that sets over the 2 cables to keep it from moving one way or the other.
My question is would you have to bond all of the individual items together to insure a quick return fault path should the temporary lighting wiring happen to rub into the cable or posts?
The temp lts are on romex pierced through the hot and neutral , the ground is not terminated anywhere on the tent posts and even if it was, without bonding each and every joint there is no way of insuring a solid return path.
Is there a requirement for gfi protected wiring for tempoarary lighting in this instance?
