K8MHZ
 - Electrician
This is on the end of an old train terminal building.  The box on the right is spliced directly into the service drop for the building.  The weather head, on the left, feeds a 240 volt single phase meter.  The conduit from the box on the right goes into the ground.  It is not connected to the meter at any point.  If you look close, you can see a piece of either UF or NM cable hanging out the bottom.  There is a door in front with a wing nut on the left and hinges on the right.  Whoever was in there last clamped the door over the cable.
Using Photoshop, I was able to filter through the paint and read what was on the cover. It reads:
Squared D Inc.
Chicago, IL U.S.A.
(Old building block style 'D' logo)
The letters 'FF' in a diamond logo
Condulet
Pat. Issued and pending.
All the above are in all caps and covered with a thick coat of paint.
The conductors, cloth covered, enter the box through tube type bushings.
Has anyone ever seen anything like this? If so, what is it and WHY is it on the line side of the meter with no fuse, breaker or disco?
To me, this thing looks dangerous as the old conductors to the box are spliced in and hot. The meter below, a digital CL 200 was on and running.
Squared D Inc.
Chicago, IL U.S.A.
Condulet
