Mike Lang
 - New Jersey
I took permits out on a residential renovation.  The job has been framed and the plumber is currently working on the job.  Last friday a delivery truck hit the service drop with the box of his truck and started a fire.  One of the hot legs got sliced open by the truck and got welded to the bare neutral.  The transformer did not blow and sent 120 volts with a ton of amperage across the neutral bar and out through all of the neutrals and grounds.  The bare water pipe bond lit up the insulation and the ceiling joists across most of the house and then down into the basement.  Pretty much everything it was in contact with.  Most of the visible damage is in a straight line following the water pipe bond. Although the existing part of the house is still sheet rocked and I can't say what condition these wires are in.
Now here's my problem, I'm not comfortable fixing the visible stuff and just praying that the hidden wires are all OK. I'm getting the feeling that the insurance adjuster is not OK with me re-wiring the entire house. How would you guys deal with this?
I don't want to get a phone call a year from now that the house went up in flames at 3am with a family in it. I want to re-wire the entire house because I can't say that the other wires are all in perfect condition since I can't see them.
