dclauria
- Northern Michigan
I am bidding a home in Michigan for which the plans show 3 solar panel arrays on the roof - 10x10, 14x10, and 20x10.
The home specifies a 300Amp service, and "electrical contractor shall coordinate work with the alternate energy (solar, wind turbine etc.) supplier"
However, I've been told the solar installation is something future that the homeowner will take care of.
I have wired several homes designed by the same architect in the past. He almost always specifies a 300 or 400Amp service, but to keep costs down, we use a POCO 320Amp meter base with double lugs feeding two 200Amp disconnects or panels, depending on location. (On this project the panel location is in the basement mech. room - approx. 50' from service location)
What design info would I need to keep in mind to make it simple to integrate a solar installation w/grid connection? Can I bid my standard 2 loadcenter panel service w/4/0AL SER, or do I need to plan on a 300 or 400Amp disconnect w/conduit & panelboard? - I usually use SqD products.
Thanks for any help from those of you with more experience on this.
