Like I guess it's called, a rolling offset. I have the green book from Mr. Cox on bending. I don't see anything on matching existing bends. Do I need to find the pipes center of bends, and degree? Then mark that measurement on a new stick, and bend it at the center mark on the hand bender? This is probaley a tough one to answer on a forum. A guy I was working with showed me a formula like square this number, then square this number, then add them, then find the square root of that number. Sound familar? The guy lost me, I don't know what measurements he's talking about. Thank you for your help.
there are two groups of people in the world.... center to center, and
outside to outside.... and it's always fun watching one of each of them
try to work together to get something bent....
i'm assuming this is with EMT, and it's a big enough diameter pipe that
you can't scooch it easily... lets' say 4" emt, for sake of argument....
i can show you the math to do "rolling" or compound offsets, but you don't
need that, you need to get this done...
get a scrap of 1/2" emt a couple feet long, bend it to match the pipe you
are trying to match..... take it down and measure the angle with a digital
level. don't have one? they aren't expensive.... consider the purchase of
one.
hold a straight piece of 1/2" emt alongside the target pipe, measure how
much offset there is, measuring with the axis of the offset.... in line with
it, so to speak.
now, you have an angle and an offset amount, center to center.
go bend it, leaving it a few inches longer than the pipe you are gonna
match.... put it up in place, and cut the end where you want to have
the coupling if you want it to match.
install pipe.
have fun.
now, if what you mean is doing something of a concentric nature,
there is a good way to do that, but it involves segment bending,
a piece of elastic with 1" marks on it, and the willingness to learn
how, which means ruining some pipe.
and learning about developed length.
if you are doing ridgid, and have to cut and thread before bending,
the quick and dirty way i just mentioned may not work for you.
