I'm going to be installing 5 light pole bases which will be a first for me. The specs say 5' in the ground with rebar cage but that's about it. How do you guys make the rebar cage? Sections tied together to make a square then several of those tied to vertical sections to make a 3D rectangle? I saw one post where the horizontals were bent in circles with verticle bars tied to it to make it a cylinder. I guess you would do that with a torch? Also I planned on putting my sono tube all the way down into the ground the 5 feet but I saw an older post where some disagreed with that. Also can fiber reinforced concrete take the place of rebar? I can make the decision even though the specs say rebar. The specs are borrowed from another contractor that put poles on this property previously.
well, the pole manufacturer may have a "standard" base for a specific
pole and light head combo drawn up, but as was mentioned, there
probably better be an engineers stamp somewhere on this before you
dig the hole....
once you have a drawing, and holes dug, and a rebar cage built and sitting
on chairs in the hole, and a sonotube stuck in there and plumbed and set
to correct height.... then you can put in your part.. the j bolts, pipe, etc.
i've done a lot of these over the years, and here's how i do it.... most
guys drill a piece of plywood with the bolt pattern... i get the pole
makers cut sheet, and go to my little sheetmetal shop a mile up the
road from my house.... and have them shear some 14 guage or 12 guage
mild steel, and punch the holes in the correct places to fit the bolts.
then i grease the threads on the j bolts, and using the correct galvanized
nuts, put the first nut on all the way down, and back it off a turn.... then
i put the bolts in the template, and run the other nut down tight, putting
the j hooks facing each other.... put a couple stakes across the sonotube
and sit the template on them.... put pipe up the center, out the top, and
stubbed thru the side of the sonotube deep enough to meet correct depth
required below finished grade....
and i MAKE SURE that the bolts are oriented so the heads on the poles
line up in whatever pattern the drawings show.... putting a straightege
on the bolts and sighting at the next base in the row works well...
i did mazda's design center in calif, and set the poles.. the bases were
done by someone else... and after the poles were set, mazda took
aerial photos  of the lot, and circled the ones where the light heads
were not perfectly straight, and said.... "fix these..." after the job was done.
i've been told metal templates are a waste of money, but one base with
with one bolt off, so you can't set the pole cancels that out, in my book.
