Billy D
 - Massachusetts
I was wondering if someone could help me with this question.
In article 680.42 Outdoor Spa Installations talks about the type of wiring you can you use to wire the hotub. The way I interpit it is that you can use romex cable, with unisulated grounding conductor, from the branch circuit device to your outdoor disconnect. Then from your outdoor disconnect to the tub control panel you can use UF cable, still with unisulated grounding conductor. 680.42.2(c) states that the 12 AWG grounding conductor insulated or enclosed conductor with in the outer sheath of the wiring method shall be permitted to be used for the connection to motor, heating, and control loads. I t seems to me they are talking about the wiring on the outside.
Thank You
Thank You
