Sir String
12/2 MC cable in a 5" box.
You take the green wire & secure it to the box with a green ground screw. Thus grounding the box.
Do you also need to bring a tail to the ground screw of a duplex receptacle?
If yes, why? If the box is grounded, then so is the receptacle through the 6/32 screws. Or alternately, if the receptacle is grounded, then the box is grounded through the 6/32's.
I'm feeding a 5" box for quad receptacles plus 2 12/2 jumpers to other boxes. I end up with 6 grounds under a wire nut.
