Riograndeelectric
 - Lakewood Colorado
question.
(" In any area specified in 210.12(A) where branch- circuit wirng is modified,replaced, or extended, the branch circuit shall be protected by one of the following")
the NEC seems vague on this article. seems to me that 210.12(A) is talking about branch ciruit wiring only .If I am doing a service change this would be considerd as modification and or replacement . CAFCI protection would be required for branch circuits listed in 210.12(A) although the branch circuit wiring in mitself is not being alterd ?
What if you are changing out the Branch circuit protection- circuit breaker on non grounding circuits (2 wire circuits) with GFCI breakers would the circuit now require to also have to be protected by an CAFCI.
