ent in cold air returns
Thanks Dennis, the ent I'm running will be running parallel in the cold air return joist for about 12" to 18" then 90's out of the joist space. I'm using this as a chase to pull catv later. I hope the 12" to 18" parallel is not a big deal and pass inspection. If not, I'll just remove it and go buy 1" fmc.
With most construction today using engineered "I" joists sometimes I will pan off the "I", leaving a space that is not within the environmental air handling space, if I must run something parallel to the joist.
