using 240 V cicruit for 110 V
cmiller41
New member
What is the code section that says you CANNOT tap off one leg of a 240V and use as a 110 so that you have a 240V circuit (breaker) in a J-Box and tap one leg and run 110V from it so breaker feeds both
There is no code section that says that.
We can do that assuming there was a neutral with the circuit and the overcurrent protection is correct.
Would this also mean that you could by rights install a 20 amp 240v feed to an outside condensing unit, pull a neutral along with it, and tap off of the line side of the disconnect to feed a 15 or 20 amp 120v GFI Receptacle next to the pullout?
If you're going to supply more than one 120V load, I would make it a MWBC downstream of the 240V tap to balance the load on the phases and minimize the current on the grounded conductor.
