Minimum Clearance between Low voltage cables and power cables
What is the minimum clearance either horizontal or vertical clearance needed between the low volatge and power cables noting both of them are on different cable trays.
API 552 is a petrochemical industry standard that addresses separation. It is fairly conservative, but it is the only document I have found covering separation distances.
