What happened to the grounding screw?
K8MHZ
I went to a hardware store and bought a couple Levition three way switches.
There was no grounding screw on either switch.
So when I got to my computer I checked Leviton's site. Their pic of a three way shows a ground screw present.
Is there a rational explanation of this somewhere?
Little Bill
Tennessee NEC:2017
Semi-Retired Electrician
Sounds like either mis-packaging or a MFG. defect.
Take your meter and see if it's truly a 3-way.
infinity
New Jersey
Journeyman Electrician
Is it possible that they're really old stock? I have a few boxes of old switches without ground screws.
K8MHZ
Too late. They have been installed and work fine.
EDIT: I called a friend that lives near the store. If there are any more I told him to get them so we could take pictures of them.
I am not ruling out the possibility of a counterfeit product.
tom baker
First Chief Moderator
Leviton has a great tech support line. 800-824-3005. I suspect they will want the orginal package, which you no longer have, and they may need some numbers off of the switch. Keep us posted.
roger
Fl
Retired Electrician
The picture on the Leviton site of the 1423-ICP switch does show a grounding type switch but it is a non-grounding type device. I think some other manufacturers still offer non-grounding switches as well.
Roger
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
Roger
Go to this pass and seymour page and there are a slew of non grounded switches. I guess if you mount the switches directly to a grounded metal box then you don't need it.
lauraj
Portland, Oregon
If it were a replacement with no grounding means in the box I suppose it would be permitted, but I don't see how it could be for a new installation. 404.9(B) requires equipment grounding conductors to attach to the switches.
infinity
New Jersey
Not if the box is metallic and grounded, then the 6-32 mounting screws are sufficient for grounding a switch. {404.9(B)(1)}
Dennis Alwon
Chapel Hill, NC
What amazes me is that they even bother to make it without the ground. Why bother-- I don't understand the extra inventory.
