jeff48356
- Livonia, Michigan
My neighbor had a new garage built, and he did his own wiring.  He ran a 50A 240V service with a sub-panel, and installed several outlets on each wall, on separate circuits from the sub-panel.  He ran the wires through the studs, like you would normally do inside a house.  But the inspector didn't pass it, saying that it wasn't code to run wires through studs in a garage unless he finishes the walls with drywall or pegboard.  Instead of re-doing all his wiring, he decided to cover all the walls with pegboard.
What is the reason for the code saying that you can't have wires running through studs in an unfinished garage?
