qcroanoke
Sometimes I don't know if I'm the boxer or the bag
- Roanoke, VA.
- Sorta retired........
If I have a 200 amp 240 volt 10,000 A.I.C. breaker enclosure feeding a 200 amp panel with a 200 amp main 22,000 A.I.C. and the panel contains breakers with a 10,000 A.I.C. would you be surprised if a ground fault on a 20 amp breaker tripped the main breaker in the panel as well as the 20 amp breaker?
Do I have a coordination problem?
All breakers are Square D.
