Please help me out to understand the main grounding condutor size i need to install on a 400 amp single phase 240 volt service with no water pipes. This install is on a H-frame in the middle of a grass area for a cell tower. I have parallel 3/0 cu going to a tap box from a utility pole and a 3 gang meter socket plgged into it. I installed a #2 cooper tinned wire from the main tap box to 2 5/8x8' ground rods and the inspector says i have to install 2 3/4 x10' rods and a 1/0 cu wire to both rods. I talk to 2 other inspectors and they told me i'm fine. I would like to get your thoughts on this
thanks
thanks
