Cleveland Apprentice
- Cleveland, Oh
I never encountered this situation and need advice please:
A few months back, I've purchased a Siemens 2424 loadcenter MLO. I installed it as a sub-panel in a dwelling. However, there is a problem with panel cover and insert. I tried to put the cover on but the insert, after knocking out the breaker cover tabs does not align with the bus. I tried to turn it upside down and still doesn't align. I unscrewed the two screws from the insert that connects to the cover, turned it upside down, and reattached it to the cover. I was able to align the breakers in the opening of the cover, but I now need to fill in some of the openings of the insert with plastic blanks which cannot be used because they align directly over the main lug terminals.
I believe what happened was that someone purchased this panel before me, returned it. and I ended up buying it. While this person had it, they shifted the bus bar platform upward in the box, using the pre-drilled hole and slots on back. Unfortunately, I didn't check the cover and insert on the cover to ensure they align with the buses before I installed it. I can't adjust it now because I wired in the feeder and landed all the circuits to the breakers. I don't have enough wire length to try to shift the bus platform.
Did anyone run into a problem like this and how did you handle it? Also, does Siemens make a special order insert to align with the bus platform if it's been shifted from the original position? Thanks again!
