OSHA Warning of Incorrectly refurbished circuit breakers.
http://www.osha.gov/SLTC/electrical/hazard_alert.html
Although the specific breakers generally used in areas that fall under MSHA authority OSHA found it necessary to issue the advisory. The following statement within the warning also highlights OSHA's position on equipment listing requirement.
"A workplace under OSHA?s jurisdiction generally must use circuit breakers approved (tested and certified) by a Nationally Recognized Testing Laboratory (NRTL) that OSHA recognizes to test the particular type of breaker. The NRTL?s mark that appears on a breaker indicates that the NRTL properly approved the breaker. OSHA can cite employers if they use breakers not properly approved by an NRTL."
