I've read through several posts about this but couldn't find a good reason as to why this is even used. In 2001, the company installed a Delta Delta 13.8/480. Later grounded the B phase. No problems encountered. One of the buss ducts it fed had all the equipment grounded with ground rods. That same ground from the B phase is ran to the buss duct as well. If I wanted to remove the corner ground, what type of problems should I expect if any. And the main question is, WHY have a corner grounded Delta to begin with?
