I have an enclosure that I want to come out of and would like to use an LB to route the conductor out of the enclosure and along the wall. The conductors are (2) sets of parallel 3/c 4/0 cables routed in a 2.5" conduit. I would like to come out of the enclosure with these conductors through an LB and the route the cables in a 2.5" conduit along the wall.
My first question is can a 2.5" LB be used for these conductors? I'm not sure if this adheres to 314.28?
Secondly how much space is required for the installation of the 2.5" LB. The enclosure only sits 8" from the wall so there is only 8" between the side of the enclosure where the cables are leaving and the wall. Is this enough room to install a 2.5" LB or do I need to move this enclosure away from the wall more? Is there a code section that specifies this clearance?
