Mass_Inspector
- Mass
Hello all,
My question is if you?re installing a common grounding electrode conductor from the service equipment( meter socket) to the first grounding electrode (from the meter to the 1st ground rod) that has to be continuous cunductor. But if I have to install another ground rod is that called a bonding jumper? Or a grounding electrode cunductor? And does the common grounding electrode now have to be replace because it has to go to the 2nd ground rod now?
