alaskan JW
- Anchorage,Ak
I am wiring up a new job trailer and am wondering if MC is allowed for my branch circuits. I believe i have seen MC used before. If not i will use EMT.
Thanks!
Thanks!
Yes, check 550.15.
As far as job trailer not being a mobile home, I have seen a couple that this would be debatable,
If it is a mobile or manufactured home it will have a label that states that.
Most job trailers are Manufactured Buildings and Article 545 applies.![]()
There is not much to 545. The OP question is not really answered in 545.
I think Ch 1 - 4 are all OP needs concerned about. I also think he can use any wiring method he wants as long as requirements for the method he chooses are met.
Is this "Job Trailer" not an onsite contractors trailer as described in 550.4(A)?
550.2 Mobile Home. A factory-assembled structure or structures transportable in one or more sections that is built on a permanent chassis and designed to be used as a dwelling without a permanent foundation where connected to the required utilities and that includes the plumbing, heating, air-conditioning, and electric systems contained therein.
For the purpose of this Code and unless otherwise indicated, the term mobile home includes manufactured homes.
I do agree if it is a mobile or manufactured home it will have a label.
I think Ch 1 - 4 are all OP needs concerned about. I also think he can use any wiring method he wants as long as requirements for the method he chooses are met. This is not one of those occupancies that prohibits the use of a particular method like we have with NM cable in places of assembly or something like that.
The key area to look for description of type of use is located on the backside of the panel cover door. In the picture attached, this type of construction trailer is an industrialized building which is a manufactured building.
