I'm a little confused. I'm evaluating a 3M DBY Direct Burial Splicing Kit for use with low voltage lighting. The kit contains a gel sealant and wire connector. The kit is rated for 30 volts (another is rated for 300 volts). I've been through the specs carefully and there's no rating for maximum amperage.
In the past I've heard that some gel-filled wire nuts are only good up to 15 amps. An lv system run can go up to 25 amps, so I'm wondering how to know if the 3M kit will be up to the task.
Any help?
Here's the product link: http://multimedia.3m.com/mws/mediaw...Y0YOY9Tfwvrfdv_IwUTfwUTfTTTTTT--&fn=DBYDS.PDF
Any help?
