7 ton roof top ac/heat unit
amge
does anybody know the electrical spects on 7 ton 208 volt 3 phase unit with heat. I am trying to give an estimate but do not have any spect for the wiring.
Thanks
I do alot of HVAC work. Every unit is different, depending on the SEER & EER. Your missing alot of BASIC infomation. But your in the 50 amp range.
They dont make a 7 ton unit. That being said, I felt like being nice this morning so I did a selection for you. I based it off of a 12 KW heater which is about where you would be for a 7.5 ton unit. See attached.
  • 7.5 Ton Selection.pdf
