Ok so heres the issue...I work at dangelos part time and over the years we have had the same two steamers and randomly they would burn out the neutrals in the cord cap. The owner had tried to change plugs....cord caps....circuits. nothing has been working. So today I smelt an electrical burn smell and saw that the steamer cord cap was charred black. I shut the breaker off and tool the cord cap off and examined it. The connections were tight but the neutral wore going to the steamer was charred. So I decided to check the plug in the wall to see if that neutral was burnt up as well..it wasnt. Well there was another steamer running in the building so.I decided to get my meter out. I have a plug in device that allows me to read the amps on a circuit without splitting the wires. And I measured 15 amps on the hot....which is ok......but I was reading 120 amps on the neutral!!!!!!!! Why would this be happening. Bad steamer?? The breakers have never tripped cuz of this.
