 - Wisconsin
 - PE (Retired) - Power Systems
In my area, most of the utility transformers are either padmount construction or have top mounted bushings for use in open air. Most of our industrial transformers are arranged with side mount connections for close coupling to switchgear.
Moisture absorption by an un-powered transformer is almost entirely dependent upon the type of the transformer insulation, and if the relative humidity condenses.
I had one customer that kept his dry type transformers under a tarp with an energized 100 watt light bulb to keep it above ambient.
