First time I have seen these, steel connector that pushes through the knock out from the inside of the box. It is flush on the inside of the box with about 1/2" sticking out of the box. Romex is fed into the connector and then the connector is crimped with pliers or a special crimping tool to secure the romex. Any one seen these? Are they UL approved? Do you need a special tool to crimp the romex?
Thanks
Thanks
