sparkey874
- Erie, PA in the Civilian work
Ok, we are doing a rehab on a building on a military base and are replacing the old bathroom receptacles with GFCIs. The building wiring is old and only 2 wires were run to the orginal recpts. Now my question is will this meet the NEC Code? My Chief and the NAFAC Officer say it will because there is a GFCI present in the bathroom, but to my understanding, for proper operation a ground wire must run from the GFCI receptacle back to the PP to be a good circuit. Does the NEC say anything about this? I have a copy of the 2008 NEC and am looking also. Thank you in advance
CE2
CE2
