jjhoward
 - Northern NJ
 - Owner TJ Electric
I have installed many residential over head services with 2? PVC screwed into the top of the meter pan?s hub.
Either I have screwed in a male adapter into the meter pan hub then inserted/glued the PVC stick or screwed in a threaded offset and then inserted/glued the PVC stick.
It always seems that PVC thread and the hub thread do not match. But threading RMC into the meter pan?s hub goes fine.
1) Is the thread of the meter pan hub and the PVC thread different?
2) Is screwing the PVC fittings into that metal hub a code violation?
3) Is this connection (PVC to metal hub) not rain tight?
Different question, same meter pan hub:
Does anyone every install caulking or a gasket where the hub sits on the meter pan surface?
I have a year old install, & it seems like water is getting into the panel via that damn hub. Looks like the water is either entering the meter pan via the PVC to hub threads or the hub to meter pan interface.
Thank you.
Thank you.
