The disconnects I installed did not come with a grounding lug or bar. I tapped and threaded a s.p.a ( butt splice ) to the box and have 3 #12 ground wires under one screw, inspector says not rated for more than one wire, how many grounds the same size can you terminate under one screw in a panel or service disconnect. This does not sound right.
